hosregla
Dec 04, 2016Aspirant
wired router and 5 switches
Hello guys
how is the best wired. i have ffth with AMPER eg-663
WIRED: G01 EG-663 ---> RACKG SWG (.203) G01 40m
G02 EG-663 ---> RACKAB SW (.200) G01 38 m ------> SWB (x.201)(G47SWA) TO G23(SWB) 20 cm
G03 EG-663 ---> CPU HP 5100
G04 EG-663 ---> RACKCD SWC (202) G48 66m-71m
I would like get LAG with each switches.
SWITCHES modelo FW ports situation
192.168.0.202 GS748Tv4H2 5.4.2.18 // B5.3.0.2 48 rack cd - Rayos - PLAN.0
192.168.0.200 GS748Tv4H1 5.4.2.13 // B5.3.0.2 48 rack ab- principal - PLAN 1
192.168.0.201 GS724Tv3 5.4.2.13 // B5.1.1.1 24 rack ab - principal PLAN 1
192.168.0.203 GS724Tv3 5.4.2.13 // B5.1.1.1 24 rack gh - PLAN 2
192.168.0.204 GS748TV5 6.3.1.11 // B1.0.0.4 48 RACK E_F PLAN_01_PAPE
Thks by your time ;)
byes from SPAIN
It seems that your goal in setting up LACP is to improve the read/write speeds between PCs, am I right? It seems your concern is similar to this forum link I found online. Kindly access and read it.
Doing an iPerf test would help. Here are the links I found online that you could use as a guide to perform an iPerf test.
What is iPerf and how is it used?
Basic Network Testing with iPerf
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi hosregla,
Are you going to cascade all of the switches having a LAG configuration in between?
Kindly access the links below as reference guide on how to configure LAG:
Configuring the Link Aggregation Group (LAG)
How to set up Link Aggregation
DaneA
- hosreglaAspirant
Will I get better performance, if the switches do not go through the router, and only one of them goes through the router ?.
The DC, and SQL SERVER, PACS DICOM are connected in 192.168.0.200 GS748Tv4H1 5.4.2.13
How would you connect them?
Can I connect two switches in lag mode with x.200?
Thnks by your time ;)
- hosreglaAspirant
i have find this KB http://www.downloads.netgear.com/files/GDC/GSM7352SV2/how_to_configure_lag.pdf
but what is the best practice? 1º each switch to router or 2º each switch, in cascade by LAG sw1 ---LAG 2 wired-- sw2 ---LAG 2 wired SW3 -- LAG 2 wired SW4 -- (DC,SQL SERVER 2012,DICOM PACS are in sw 1.
