pezza72
Jan 31, 2025Aspirant
XS716T Mounting Brackets
Hello, I have just purchased a used XS716T (I know it is now discontinued - which I will take the risk for) and I plan to mount this to my data rack. Worst case scenario is that I have to pur...
BrianL
Feb 03, 2025NETGEAR Moderator
Hi pezza72,
Welcome to the community!
The XS716T is indeed EOL and the Rack-mount installations use a 19-inch (48.3-centimeter) EIA standard equipment rack. Have the product registered via https://my.negear.com/ and see if support can supply /or source you a rack-mounting kit.
For reference, you can look at the product hardware installation guide,
Kind regards,
BrianL
pezza72
Feb 03, 2025Aspirant
Thanks BrianL
Yeah, I checked out that guide but it doesn't mention the spec of the actual brackets. It just says use the mount kit provided. I also couldn't find any specification on the distance of the holes at the side.
If I am able to, I will register this as you suggested.
It should be arriving in a day or two anyway so I will be able to check then. I was just hoping to order the mounting kit in advance to save me waiting when the switch arrived, but nothing really urgent.
Thanks for your help
Andrew
