DILVISH
Sep 15, 2025Tutor
KERNEL ERRORS on WAX214
Hello !
Since the last firmware update, I get these errors on my WX214 antenna.
The antenna works, but some peripheral (wifi camera) disconnect regularly (they are next to the antenna 5 - 10 m).
Attached file : the error log after a reboot.
After reboot, the incrimined peripheral must be reconnected manually but disconnect after several days.
Can you help ?
Many thanks,
Best regards
- DILVISHTutor
I change the camera. It's the only peripheral who disconnect. For the kernel errors, I don't know but the antenna seems to work properly.
Thanks for your help.
So can this answer be marked as a solution to the thread?
This log is completely volatile. After a reboot, there won't be any signs of the disconnection.
Grab the log file -after- that or these wireless devices are de-associated.
Is this one of the newer WAX214v2 model https://www.netgear.com/support/product/wax214v2/ or the earlier WAX214 version https://www.netgear.com/support/product/wax214/ ?
For completeness, include brand, model, and firmware version of the WiFi camera.
Those are KERNAL errors. System level.
Have you factory reset the WAX and setup using a wired PC and web browser with the AP connected to a host router?
- DILVISHTutor
no, as I have only a deco problem with one peripheral, I choose to wait and decided to change the camera instead.
