c420ramsay
Feb 28, 2020Follower
Advice in relation to daisy chaining a 16-Port PoE/PoE+ Gigabit Ethernet switch GS116LP
Looking for some advice: I have one GS116LP 16 port GB switch and I am looking to Daisy chain another one to increase capacity. Am I safe enough buying the same one again to daisy chain to it or would I be better buying the model up with an increased PoE power supply at 183W rather than another at 76W? The model for the one up is the same but with a higher power supply from what I can see (GS116PP).
Does it depend on what you have connected to them?
Ìt depends on the number of ports you need, on the PoE standard (PoE, PoE+, ...), the number of PoE ports, ...
1 Reply
