Tobarus
Jan 20, 2018Aspirant
Can I get 10gigbit between my PC and NAS with this switch?
Hi there, I'm very intersted in purchasing the GS110MX-100NAS switch (unmanaged - I'm very new and don't need these features for home (wife and I)). Simply put, I'll be connecting a 10gigbit ...
- Jan 20, 2018
Hi Tobarus,
Definetly you will get fastest speeds if you use 10Gbps connnectivity instead of 1Gbps. However you also have to take in consideration the hard drives that you are using to be able to achieve the 10Gbps :
if you are runnnig SSD definetly you will be really close to 10Gbps but if you are running HDD the transfer speed will be limited by the type of RAID that you have configured on your NAS. However maybe you will not be able to get 10Gbps speed you definetly will notice and improvement on the transfer speed between your NAS and PC.
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
XavierLL
Jan 20, 2018NETGEAR Employee Retired
Hi Tobarus,
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
Tobarus
Jan 21, 2018Aspirant
Thank you for the answer Xavier,
I think you've pretty much answered my question. Yes, the PC and NAS are up to the task, but i guess I wasn't exact enough with my question. I'll basically be using the NAS and PC for video editing, etc (the NAS is obviously the storage portion), with huge amounts of data being transfered.
Basically, assuming a setup where the internet/router is only connected to a gigabit port, however, the NAS and PC are both connected to the only two 10 gigabit ports available, assuming the NAS and PC are up to the task, they connection between the NAS and PC should theoretically be at 10 gigabit speeds, correct (ie - the internet/router is completely segregated from all of this).
Basically, I'm looking for the fastest possible speed between the PC and NAS specifically (everything else does not matter). ie - I'm looking for 10 gigabit speeds (of course as you said, assuming all the other components are up to the task - but specifically looking at only the switch's perspective).
On a side note, the product states two 10 gigabit "upload" ports. When referring to "upload", netgear means the two ports upload and download data at 10gigabit, not just upload, correct?
Thanks again!
