Jcarpenter80
May 07, 2022Follower
Devices drop connection
For several years my business partner has used a Netgear ProSAFE GS108 switch at his desk. He has one network plug but three devices to connect. Yesterday he lost connectivity on all three devices. A...
DaneA
May 15, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Based from your initial post, whenever you connect a computer to the GS105, the other devices connected to it loses connection. But, when you disconnect the same computer from the GS105, the other devices gets connectivity again. It seems that the problem is not the GS105.
Be informed that the GS105 is a pass-through, unmanaged switch. Its main purpose is to extend the LAN so that you connect more devices like a PC, network printer, etc.
Is your modem a modem-only device or a combination of modem & router?
Is there a router connected to the modem? If yes, is the GS105 connected directly to a router?
When you connect the computer directly to the GS105, does it obtain a valid IP address?
DaneA
NETGEAR Community Team
