hjmalves
Nov 14, 2017Aspirant
Netgear support - who? where? how?
Hello I am from Portugal and I am trying to open 2 RMA cases for 2 damaged GS116 switches. After submitting in support area I get 2 case numbers: 29242293 and 29242267. Next I get a support ...
DaneA
Nov 15, 2017NETGEAR Employee Retired
Hi hjmalves,
Welcome to the community! :)
Kindly try to use the Guided Assistance (which is highlighted in "pinkish red" button) in the GS116v2 product support site here to process an RMA for your GS116 switches.
DaneA
NETGEAR Community Team
hjmalves
Nov 15, 2017Aspirant
Ok. That worked. Thank you for your help
- DaneANov 15, 2017NETGEAR Employee Retired
Thanks for the update. You're welcome! :) I'm glad to know that it worked. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
