hjmalves
Nov 14, 2017Aspirant
Netgear support - who? where? how?
Hello I am from Portugal and I am trying to open 2 RMA cases for 2 damaged GS116 switches. After submitting in support area I get 2 case numbers: 29242293 and 29242267. Next I get a support ...
hjmalves
Nov 15, 2017Aspirant
Ok. That worked. Thank you for your help
DaneA
Nov 15, 2017NETGEAR Employee Retired
Thanks for the update. You're welcome! :) I'm glad to know that it worked. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
NETGEAR Community Team
