bsun003
Oct 27, 2016Aspirant
No Ethernet Connection after Connect with GS105 Switch
Hi all, I have some questions about our new bought GS105 switch. It is said that this model is a unmanaged switch so that I can plug into cables and make them communicate. However, when I connect...
- Oct 27, 2016
Problem solved because the USRP default IP address is: 192.168.10.X. I can't make wired connection to automatic DHCP. I should manually set the IP address and also try to avoid IP address collision.
bsun003
