PMICD
Jul 21, 2022Aspirant
Two of the four ports are not working on my internet switch & I can't reach support
Model # GS105v5 Serial: 3TL11754A6145
schumaku
Jul 22, 2022Guru - Experienced User
https://www.netgear.com/support/product/GS105v5.aspx -> [Guided Assistance]
or
https://my.netgear.com/ -> Select the registered device -> [Request Hardware Support]
- PMICDJul 22, 2022Aspirant
Dear Guru;
Thank you for sending the links to more information. I found troubleshooting suggestions that I haven't tried. I am not the person who will be following up on this so it will be a week before the suggestions are tried. I will get back to you then.
Thank you,
Pati
- schumakuJul 22, 2022Guru - Experienced User
If the dead ports are not caused by some loop protection, well possible you face a hardware issue.
