sedcom_pm
Jul 07, 2017Aspirant
FVS336Gv3 PPTP VPN for macOS Sierra
Hi Netgear community, One of our sites has a NETGEAR ProSafe™ Gigabit Dual WAN SSL VPN Firewall FVS336Gv3 which has PPTP Server enabled and setup with working users for Windows OS, there is 1 use...
JohnC_V
Jul 09, 2017NETGEAR Employee Retired
Hi sedcom_pm,
Welcome to our community!
Apple already dropped the support on PPTP, I don't think that if we run any PPTP 3rd party client it would still work. I may advise you to please try to give a call on apple support just to make sure what 3rd party application are we going to use that will work on your MAC OS Sierra.
- JohnC_VJul 12, 2017NETGEAR Employee Retired
I would like to have a follow-up on this. If you were able to contact apple support and everything works ok now. Please keep us posted.
- sedcom_pmJul 19, 2017Aspirant
Hi JohnCarloV,
My user tried FlowVPN and that did not work (with PPTP), the user reports that it disconnects automatically.
Do you have any instructions/step-by-step guide in setting up the SSL VPN for a user (who will be using a Mac), and also what client he needs to use on the Mac to make the SSL VPN connection. The Mac Clients are all asking for a certificate from the host server (The Netgear FVS336Gv3 in this case) but I am unable to generate one.
Thanks in advance.
- JohnC_VJul 19, 2017NETGEAR Employee Retired
My apologies but SSL VPN for Mac is not supported by our firewalls. We can only use IPSec tunnel for your MAC and even the VPN built-in app will work for this setup.
Please refer to this manual for setting up the firewall and this link is for your MAC.
