Dion07
Feb 24, 2017Aspirant
Netgear Prosafe Router Model SRXN3205 - Slows down Internet Speeds
Our network speeds are supposed to be getting 200 Mbps download and somewhere around 10-15 upload. We were using Comcast -> NetGear Nighthawk R700 and we were getting the full 200+ download speed on ...
- Feb 26, 2017
Hi Dion07,
Welcome to the community! :)
The SRXN3205 has a LAN-to-WAN throughput of 60Mbps which is lower than your subscribed 200 Mbps download speed from Comcast that is why it slows down. You may check the SRXN3205 data sheet here.
If you want to achieve your goal to have VPN connection and at the same time having a 200 Mbps download speed, I suggest you a VPN firewall that has a LAN-to-WAN throughput greater than 200 Mbps like the following: FVS318Gv2, FVS318N, FVS336Gv3 or the SRX5308. Kindly check their specification and comparison on the data sheet here.
DaneA
NETGEAR Community Team
Dion07
Feb 26, 2017Aspirant
Well that answers my question to my issue straight up. Thank you DaneA.
BTW, where can I find those datasets for the routers? I was not able to find those.
DaneA
Feb 27, 2017NETGEAR Employee Retired
You're welcome! :) You could find information about NETGEAR ProSAFE VPN firewalls here.
Cheers,
DaneA
- Dion07Feb 27, 2017Aspirant
DaneA, thank you again!
Why do the WAN ports even support Gigabite speeds if they can't do WAN to LAN throughput faster than 100? That sounds silly.
