flattened
Oct 11, 2016Apprentice
UTM9 Mac OSX Sierra - IPSec VPN
Hi all, I have used the very useful PDF to enable a Mac on latest OS X Sierra to the UTM 9. PDF https://docs.google.com/viewer?a=v&pid=sites&srcid=a29zc2Jvc3MuY29tfG1haW58Z3g6NzZkNDZhYTNiYTkw...
- Dec 09, 2016
I'd like to end this as closed. We achieved the required result by reverting back to standard PPTP using a 3rd party paid app on the Mac called Shimo.
DaneA
Oct 11, 2016NETGEAR Employee Retired
Hi flattened,
Kindly access the article below and it might help:
Mac OS X VPN Client install with ProSAFE VPN Firewall/Router
DaneA
NETGEAR Community Team
flattened
Oct 12, 2016Apprentice
Hello Dane,
Thankyou very much for this guide, I have followed it to the letter. A connection is established but I still cannot access any resources. I guess there are more steps for me to take now? A static route? A mode config?
I disclose right now that I really do not understand IPSec tunnels and have been forced down this route by the latest Mac OS release and our client insisting that he use it ... The previous PPTP connection that he had in El Capitan is now depreciated/removed in this latest 'Sierra' release.
- DaneAOct 12, 2016NETGEAR Employee Retired
Hi flattened,
Let me share the old forum link below. There are a lot of suggestions you can try.
https://community.netgear.com/t5/VPN-Firewalls/Mac-OS-X-Yosemite-VPN-setup/td-p/985348
DaneA
- flattenedOct 12, 2016Apprentice
Still no luck, I'm going around in circles as many of those links I had used previous to my post here. I am establishing the link (with either IPSecuritas or the Mac stock client) but I just cannot get to the devices on the internal network... I proper hate Apple.
Additionally I have nothiced (I think) via the UTM logs that in the process of establising the IPSec connection that there IP address 192.168.10.10 comes into play somehow and I'm not entirely sure what it is.
I have used the "DIagnostics" and I can actually ping 192.168.10.10 using "Ping through VPN tunnel" check box!
The local LAN is actually a 192.168.40.0/24 range.
I have redacted the calling public IP.
2016-10-12 14:02:33 [UTM9S] IPsec-SA established[UDP encap 4500->4510]: ESP/Tunnel 192.168.10.10->x.x.x.x with spi=102136819(0x6167bf3)_ 2016-10-12 14:02:33 [UTM9S] [CONNECT] IPsec-SA established: ESP/Tunnel x.x.x.x->192.168.10.10 with spi=108165093(0x67277e5)_ 2016-10-12 14:02:33 [UTM9S] IPsec-SA established[UDP encap 4510->4500]: ESP/Tunnel x.x.x.x->192.168.10.10 with spi=108165093(0x67277e5)_ 2016-10-12 14:02:33 [UTM9S] Adjusting peer's encmode 61443(61443)->Tunnel(1)_ 2016-10-12 14:02:33 [UTM9S] No policy found, generating the policy : 20.0.0.71/32[0] 192.168.40.0/24[0] proto=any dir=in_ 2016-10-12 14:02:33 [UTM9S] Using IPsec SA configuration: 192.168.40.0/24<->0.0.0.0/0 from utm_remote1.com_ 2016-10-12 14:02:33 [UTM9S] Responding to new phase 2 negotiation: 192.168.10.10[0]<=>x.x.x.x[0]_ 2016-10-12 14:02:32 [UTM9S] purging spi=187648033._ 2016-10-12 14:02:32 [UTM9S] Sending Informational Exchange: notify payload[INITIAL-CONTACT]_ 2016-10-12 14:02:32 [UTM9S] ISAKMP-SA established for 192.168.10.10[4500]-x.x.x.x[4510] with spi:287fca8f27ace56e:4d9167164d0dc7dd_ 2016-10-12 14:02:32 [UTM9S] NAT detected: Local is behind a NAT device. and alsoPeer is behind a NAT device_ - DaneAOct 13, 2016NETGEAR Employee Retired
Hi flattened,
Have you tried using another MAC computer or a Windows PC and try to set up a client-to-box VPN with the UTM9s in order to isolate the problem?
DaneA
