BDubUT's avatar
BDubUT
Antenna Gain for 5Ghz radio on WAC510
On the product page, the WAC510 antenna gain for the 5Ghz radio is listed as 6 dBi:
https://www.netgear.com/business/products/wireless/insight-managed-wireless/WAC510.aspx#tab-techspecs
However, on the data sheet, it is listed as 5 dBi:
https://www.netgear.com/images/datasheet/wireless/InsightManagedWireless/WAC505_WAC510.pdf
Which one is correct?
  • Retired_Member's avatar
    Retired_Member
    Jun 14, 2018
    Hi BDubUT,
    The correct value is 5dbi on the 5Ghz radio, as per the datasheet.
    Thanks for pointing this mistake out, we will update the product page accordingly to display the correct value.
    Kind regards
    DavidGo
1 Reply
    Retired_Member
    Hi BDubUT,
    Kind regards
    DavidGo
ProSupport for Business
