adpwl1
Aug 04, 2025Follower
IOS Apple Devices Dropping
I have WAX625, WAX610, & 605. For a number of months now, my IOS devices continue to drop their WIFI and then takes 2-5min to reconnect. I originally had Load Balance and Remove Sticky Clients c...
John217Ross
Aug 10, 2025Aspirant
Hello!
It's frustrating when devices drop their connection, especially in a technical setup. Since you've already tried basic solutions, the issue is likely related to how iOS devices interact with your multi-AP environment. Try adjusting a few advanced settings: manually select a static non-DFS channel (like 36-48) to prevent disruptions from radar detection; temporarily disable Fast Roaming (802.11r), as it can sometimes cause stability issues with certain clients; and lower the 5/6 GHz transmit power to encourage better roaming between your access points. Additionally, you may want to check your Insight logs for clues and test disabling the "Private Wi-Fi Address" on one of your iOS devices.
