bulnomali
Jan 25, 2023Follower
Is wi-fi 6 worth it over wi-fi 5?
Right now I'm looking at accespoints after getting a switch (supporting PoE+), mainly the TP-Link Omada EAP245 and the Netgear WAX214, the netgear supporting wi-fi 6 at 1.200Mbits on the 5Ghz band while the tp-link has wifi 5 yet 1.300Mbits on that 5Ghz band.
I'll be using it in a single room to make for a stable link to wireless VR on an Oculus Quest (Airlink), which requires a pretty decently fast connection. Aswell as other devices such as my laptop and my phone.
I was wondering if there are any significant advantages of wi-fi 6 in my use case or otherwise any other suggestions for accespoints.
Any help would be very much appreciated!
1 Reply
If you're doing it mainly for your occulus go with the wifi 6. The occulus supports wifi 6 and will have a better connection.
