CHlbrands's avatar
CHlbrands
Mobile apps dont get connection
Hi,
I have a question regarding the WAX630. I am getting complaints of mobile devices (smartphones) that does not load apps. The apps are of a wide variety of companies like financial services, the isp and news sites. When i restart the access point it seems to work for 5 minutes to 1 hour. The following steps have been taken to troubleshoot this:
- restarting modem/router/access point, same behavior
- updating firmware of the access point, same behavior
- factory resetting modem/router/access point, same behavior
- changing modem of the isp, same behavior
- change the access point to an other access point, apps on mobile devices work
The settings i have done are quite standard:
- reserve ip in router for access point
- change ssid and password
When i restart the access point it works for some time but stops working, i was thinking that a buffer/cache is filling up? But i am not sure. Are there any ideas how to debug and/or solve the problem?
Kind regards,
Christian
  • michaelkenward's avatar
    michaelkenward
    While many questions about standard routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Business Wireless - NETGEAR Communities
    You might like to search there for messages related to your issue.
    I will ask the Netgear moderator to move your message.
    You could also tell people what else is on the network, especially the nodem/gateway/ONT that sits between WAX630 and the Internet.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
    • CHlbrands's avatar
      CHlbrands
      Thanks for the response michaelkenward .
      I shall have a look there as well. The  ont ant modem/router is from the isp and i  can not say something about it because you need to use them. The  modem/router combo is   Sagemcom  F5359  with KPN experiabox  firmware on it.  The ONT is not visible so for now it is unknown.
      But i shall have a look in the different places   of the forum and have a look in the documentation again.  And sorry that i did not mention it before.
      Kind regards,
      Christian
ProSupport for Business
