mhuber665
Sep 02, 2025Tutor
Mounting Compatibility
Hello, I would like to replace a Netgear Insight Managed WLAN Access Point (WAX-620) with a more modern one (WBE-710 or WBE-750). The current one is mounted on the ceiling. Are the models mentione...
- Sep 03, 2025
The install guide has a photo of the mount plate. It has quite a few attachment points. Might help to compare the 2.
https://www.downloads.netgear.com/files/GDC/WBE710/WBE710_IG_EN.pdf
schumaku
Sep 03, 2025Guru - Experienced User
No, the WBE7xx have a more modern mounting system. All the current WBE71x and WBE75x model variants are using the same mount system, and come in the same dimensions. Impressingly small you will say once you have one in your hands!
