mhuber665
Sep 02, 2025Tutor
Mounting Compatibility
Hello, I would like to replace a Netgear Insight Managed WLAN Access Point (WAX-620) with a more modern one (WBE-710 or WBE-750). The current one is mounted on the ceiling. Are the models mentione...
- Sep 03, 2025
The install guide has a photo of the mount plate. It has quite a few attachment points. Might help to compare the 2.
https://www.downloads.netgear.com/files/GDC/WBE710/WBE710_IG_EN.pdf
CrimpOn
Sep 03, 2025Guru - Experienced User
The mounting bracket for the WBE710 is definitely different than the mounting bracket included with the WAX620.
There is also a detailed video guide.
https://www.youtube.com/watch?v=nO5Jp6gFgKQ
schumaku
The video is confusing where John shows these P1 ... Pn positions. These are intended for the future, implying Netgear can design different sized APs. The default are perfectly fine, no adjustments required.
