nolme
May 03, 2017Aspirant
Multiple VLAN on WNDAP360
Hi, I'm in trouble to end my configuration. Here's the network structure : Goal : - Add a Guest Wifi (VLAN 600) which can only go on Internet. Hardware : - Netgear SRX5308 [4.3.4-2] - Net...
- May 09, 2017
The WNDAP360 will not be used as a DHCP server for any VLAN. The DHCP server for both VLANs is going to be the SRX5308.
Kindly access the article below and use it as reference guide:
How do I set up one or more VLANs between a NETGEAR ProSAFE firewall and a smart switch?
DaneA
NETGEAR Community Team
nolme
May 04, 2017Aspirant
Hi, thanks for help :)
a) I can't create the 600 VLAN on the SRX because both VLAN 1 & 600 are using the same subnet.
b) I will change it & try tonight
c) The second port (12) is reserved for future use like another access point. So nothing is connected for the moment.
d) It should be done. I'll check it tonight too.
DaneA
May 07, 2017NETGEAR Employee Retired
If both VLAN 1 (Private network) and VLAN 600 (Guest network) are on the same subnet then they will be able to communicate to each other which defeats the purpose of VLANs. VLANs provides security wherein it logically separates network traffic preventing devices from listening to any network traffic on other network (or VLAN). Thus, one VLAN is equivalent to one subnet. VLAN 600 should be on a separate subnet.
DaneA
- nolmeMay 09, 2017Aspirant
- the WNDAP360 is not able to have 2 DHCP server on it (with 2 subnets then).
- the WNDAP360 can use separate VLAN ID for each SSID.
so, how can we handle this when having a L2 Smart switch ? I can create the VLAN600 on the SRX with a different subnet but how the SRX will manage this on LAN port 1 because we need to choose the VLAN 1 or 600 but not both them ?
- DaneAMay 09, 2017NETGEAR Employee Retired
DaneA
- DaneAMay 16, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to reconfigure the SRX5308 and the GS716Tv3 using the article I've shared? If yes, what are your observations?
DaneA
- nolmeMay 16, 2017Aspirant
Hi,
I'm really close to solve, I think I've done a little mistake during configuration because both VLANs are getting the same DHCP subnet (but only one can go to Internet).
Vincent
