LewisT1
May 27, 2021Initiate
Netgear WNDAP 360 - failed connection to WC9500 Controller
Hi, I have 3 x WNDAP360 Access Points that now have thesame issue - essentially the firmware image is corrupt. 2 of these corruption have occured during a reboot of the access point after an upg...
JohnC_V
May 28, 2021NETGEAR Employee Retired
Welcome to our community! :)
It seems that you are having issues with your access point. You may need to access the secret IP of the AP in order for you to gain access again on its GUI. Try to use the standalone firmware first and just re-discover it from your wireless controller once it is up and running.
I'll send you a private message.
John
NETGEAR Community Team
LewisT1
May 28, 2021Initiate
Hi John,
Thanks for ther response. Unfortunately there is no web panel to access, I don't think there is enough of a viable image on teh access points to load up the web panel.
I cannot ping the IP listed, or any other IP for that matter. The only way I can communicate with the access point is via Serial and TFTP for firmware imaging.
I am all open to further suggestions
Thanks
Lewis
