Southst's avatar
Southst
Power requirements for WAX214v2
What are the minimum power requirements when using a Poe+ injector with the wax214v2 access point? Approximately 50’ run from the Poe injector to the wap.
 Thanks.
  • Can't find or Google for documentation???
    Go to NETGEAR's site, go to Support, enter your model number, get PDF, read!
    • Southst's avatar
      Southst
      That would have been an extremely helpful response if the documentation for that wap, which I had previously read, actually specified minimum power requirements. Unfortunately, as far as I can tell, it doesn’t, so it is not.
  • schumaku's avatar
    schumaku
    It's printed about 100 times (wild guess) in the WAX214v2 User Manual
    PoE+ (802.3at) switch is required, however a PoE (803.2.af) switch might be sufficient if the the AP’s 2.4 GHz radio works with reduced transmit power. Certainly not something I'd see as a normal suggested operation status,
    The minimums are set by the IEEE standardization - this depends on the possible length of the installation. Again not something you should consider as an installation standard, unless you are to cheap to invest in industry standard PoE+ switches.
    Strictly stay with the IEEE Standards, like 802.3at or bust. Can't be easier.
    Can't wait for a new post where somebody comes and lists cable quality and length, some voltage and amps details, in-span and out-span blah, and so on. Far to many power injectors in the market, for proprietary junk like so called passive PoE devices.
ProSupport for Business
