MLO_Dukes
Oct 26, 2017Aspirant
Rejoin Wireless Controller WC7520 into stack
We have three WC7520 that used to be configurated into a stacking, one of those were problems to sync and get information from the master. To fix this issue we removed this one (182) from the stacki...
- Nov 13, 2017Hi, We explored other options but could not find a better solution then wiping out the existing configuration and re configuring everything from the scratch.
MLO_Dukes
Oct 30, 2017Aspirant
Hi JohnCarloV,
For removing it I just click delete on Stacking tab and restarted all three Wireless Controllers.
I didn't remove any cable.
Regards
LaxmankumarG
Oct 30, 2017NETGEAR Expert
Hi,
Looks like the stacking configuration was not wiped out completely when you remove the controller 182 fromt he stacking configuration. Can you factory reset the controller .182 and try to add back to the stack?
- MLO_DukesOct 30, 2017Aspirant
Hi LaxmankumarG,
Thank you, unfortunately, I can't wipe up this Controller in this moment We will be waiting for the next maintenance window to try this.
Is this the only solution or there is another thing to do?
Best Regards,
- LaxmankumarGNov 13, 2017NETGEAR ExpertHi, We explored other options but could not find a better solution then wiping out the existing configuration and re configuring everything from the scratch.
- MLO_DukesNov 13, 2017Aspirant
Hi,
Thank you, probably this solve the problem.
Best Regards,
