MLO_Dukes
Oct 26, 2017Aspirant
Rejoin Wireless Controller WC7520 into stack
We have three WC7520 that used to be configurated into a stacking, one of those were problems to sync and get information from the master. To fix this issue we removed this one (182) from the stacki...
- Nov 13, 2017Hi, We explored other options but could not find a better solution then wiping out the existing configuration and re configuring everything from the scratch.
MLO_Dukes
Oct 30, 2017Aspirant
Hi LaxmankumarG,
Thank you, unfortunately, I can't wipe up this Controller in this moment We will be waiting for the next maintenance window to try this.
Is this the only solution or there is another thing to do?
Best Regards,
LaxmankumarG
Nov 13, 2017NETGEAR Expert
Hi,
