Robert_Fernando's avatar
Jul 27, 2016
Remotly rebooting a wnap320
Hi all,
Is itr possible to send a packet across the network to a wnap320 ap to reboot it.
I like to use spiceworks network monitoring tool to detect when the wireless radios / ssids have gone offline and when true reboot the ap to bring them back online automatically.
Regards
Robert Fernando
  • To reboot wnap320
    using
    putty
    config new putty entry
    ip address of ap
    type ssh
    when ssh session starts
    type at the prompts
    1: login name AP
    2: password of AP
    3: command reboot
    Typical output
    ph1 is the name of the AP
    login as: y
    [email protected] password:
    ph1#reboot
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Robert_Fernando,
    I am not familiar with the spiceworks network monitoring tool.  You may use the NMS300 software to reboot the WNAP320 provided that the WNAP320 is within the local network.  The NMS300 is a Network Management Software for NETGEAR ProSAFE devices.  To know more about NMS300, click here.
    However, If you want to remotely reboot the WNAP320 from outside your network, then you will need to remotely access the web-GUI of the WNAP320 then reboot it via its web-GUI.
    DaneA
    NETGEAR Community Team
    • Hi all,
      I found using ssh I could connect to the netgaer wnap320 and issue the reboot command
      Robert
      • DaneA's avatar
        DaneA
        Hi Robert_Fernando,
        I appreciate the update.  Can you share here on this forum thread the exact steps you have done for the benefit of other community members?
        Is your WNAP320 access point now working fine?
        DaneA
ProSupport for Business
