haydenlawrie
Jun 20, 2016Aspirant
Remove access points from a controller
Hi I hope you guys can help. I have a set of WNDAP360's that were connected to a Prosafe WC7520 wireless controller, the AP's now nnned to installed on a different site with out a local control...
haydenlawrie
Hi DaneA
Thanks for getting back to me so quick, I have five of them and they are all doing the same thing.
1. Just a flash amber power light, no other lights at all
2. all of the default IP addresses have changed to 192.168.0.160
3. the firmware version I have downloaded and tried to apply is WNDAP360_V3.5.5.0 however even though the devices go through the install process they firmware is not applied, the current build is 2.3.0.37_1318.
If you need any more info please let me know.
Thanks again
Hayden
DaneA
Jun 20, 2016NETGEAR Employee Retired
Hi haydenlawrie,
I suggest you to upload firmware v2.1.12 instead. Click on this link where to download firmware v2.1.12. Be reminded to perform a factory reset on the WNDAP360 after uploading the firmware. Let us know the results afterwards.
DaneA
NETGEAR Community Team
