cosmolee's avatar
cosmolee
WAC510 Access Point: Cannot Update Firmware V4.0
I received a notice from Netgear that there is new firmware for my WAC510 Access Point, but I can't upgrade the firmware.   The first thing I tried was to use the "Upgrade Now" facility in the unit...
  • RaghuHR's avatar
    RaghuHR
    Apr 05, 2018
    Hi cosmolee
    Looks like you have taken the logs after the AP reboot. If you see this issue again then please take the detailed logs and send it to us.
    It looks to me there might be temporary network issue which caused this error. This we can confirm only when we look at the logs.
    Since your issue is resolved you can mark this thread closed by clicking " Accept as Solution"
    Thanks,
    Raghu
ProSupport for Business
