Constantius's avatar
Constantius
Follower
Jan 27, 2018
WAC510 LAN Power
Currently have the WAC510 Access Point set up. The WAN ethernet is connect to my modem and is not using POE, so I had to plug the access point using the 12v adapter. My question though, is if I connect an ethernet cable to the LAN port, will that be sending out power to the device it's connected to? I'm connecting it to an NVR security camera system and I don't want to short out anything. So basically does the LAN port send out POE/if it does can I turn that off?
  • Hi Constantius,
    Welcome to our community!
    WAC510 is a powered device. It does not provide any power to its port but it can receive power from a power source equipment.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi Constantius,
  • JohnC_V's avatar
    JohnC_V
    Constantius,
    I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
