cr1cr1
Oct 31, 2023Follower
WAX610: how to set up syslog log level?
I have 3 WAX610 configured in a single SSID using Netgear Insight. Whether I configure it on Insight or locally on the Web portal, I cannot choose a log level when enabling syslog to send the syslo...
- Nov 01, 2023
The BSD syslog does always start from the point where the Logger does send all messages - regardless of the Facility or the Severity - to the "next hop" syslog server. The definition of what must be stored, displayed to the admin, or subsequently forwarded to the next syslog server is always done on the destination, never on the origin (the server, the appliance, the router, the switch, ....).
Few sophisticated security appliances for example indeed provide options to control and direct the selected messages into a defined facility, into a defined path, to one or multiple syslog servers on a syslog collector - this isn't standard by far.
It's a lot of effort, inherits a certain risk to miss really critical messages or details, to hide insight from security audit - that's why there is nothing like this on most switches, servers, routers, ...
schumaku
Nov 01, 2023Guru - Experienced User
