phirestalker
Mar 29, 2023Tutor
WAX610 not finding firmware update through interface
I bought this WAP a couple of years ago. I was always able to click check for update and it would find one if available. I got notice that there was an update, and I waited for the requisite 2 days b...
phirestalker
Mar 29, 2023Tutor
That is fine. I have accepted that, but this time as I mentioned it was on the manual server and I was able to download it, but it was not found by the automated check in the firmware. I think I heard before that there is also a delay between when it is put on the manual update server and the automatic update server. Is it possible that I was just a little too early for it to migrate to the automated server?
BasuKhodanapur
Mar 29, 2023Apprentice
Hello phirestalker
What is the Current firmware version is running in WAX610? and from description WAX610 is in standalone mode?
- phirestalkerMar 30, 2023Tutor
It was on 10.3.2.2. I manually upgraded it to the new 10.4.0.5. Yes it is in local management mode.
- schumakuMar 30, 2023Guru - Experienced User
...patience. Update will become available over time. The information isn't limited to Insight subscribers only.
