ADB-UK
May 17, 2023Follower
WAX615 AP - Syslog settings come back after reboot
I have a WAX 615 AP running V10.4.0.5 and cannot turn the remote syslog off. The AP is PoE and managed directly via the WEB GUI. Web GUI -> Management / Configuration / System / Advanced / sy...
MikeD1234
Jul 17, 2023NETGEAR Expert
Hi ADB-UK,
I've tested this with an WAX615 (FW version 10.3.1.8 old version, now we're at version 10.4.1.7), setup Syslog, then rebooted the AP:
Then, disabled syslog, and rebooted:
It shows the details again, but it doesn't show as enabled.
I'll update the firmware and retest.. I'll update shortly.
Mike
- MikeD1234Jul 18, 2023NETGEAR Expert
Status update...
- AP is upgraded to latest FW 10.4.1.7.
- Enabled syslog, and rebooted.
- Disabled syslog, and rebooted.
- And, syslog is re-enabled:
I'll log a bug with the engineering team, to get this adjusted/resolved.
For now, I also tested this on FW 10.4.0.5, and issue is also present there.
I think, if you can leave it on for the time being, and once I have an update, I'll report it back here.
Mike
