jhibbard
Nov 19, 2023Aspirant
WAX625 current fw?
My WAX625 says it is running V10.12.5.108. The version available for download is V10.6.1.2. When I poke the 'update' button in my configuration menu, I get a message that there is no update. Any ...
- Nov 19, 2023
This was from a long ago concluded beta test. I do not remember if it came with that fw or I updated it (during the beta cycle). Hoping screen shot helps; see attachment
schumaku
Nov 19, 2023Guru - Experienced User
Where is this WX624 coming from?
jhibbard wrote:
The version available for download is 10.6.1.2.
Correct. V10.6.1.2.is the current production release firmware available for manual update, the live update, and for Insight managed devices..
- jhibbardNov 19, 2023Aspirant
Thanks. I have that fw d/led. I'll load it.
"Where is this WX624 coming from?" -- Sorry. I'm not clear what you are asking for; I assume "WX624" is a typo and you meant WAX625. Is that assumption correct?
- schumakuNov 19, 2023Guru - Experienced User
Yes, of course. WAX625. Where is is coming from - with the named firmware version?
