jhibbard
Nov 19, 2023Aspirant
WAX625 current fw?
My WAX625 says it is running V10.12.5.108. The version available for download is V10.6.1.2. When I poke the 'update' button in my configuration menu, I get a message that there is no update. Any ...
- Nov 19, 2023
This was from a long ago concluded beta test. I do not remember if it came with that fw or I updated it (during the beta cycle). Hoping screen shot helps; see attachment
jhibbard
Thanks. I have that fw d/led. I'll load it.
"Where is this WX624 coming from?" -- Sorry. I'm not clear what you are asking for; I assume "WX624" is a typo and you meant WAX625. Is that assumption correct?
schumaku
Nov 19, 2023Guru - Experienced User
Yes, of course. WAX625. Where is is coming from - with the named firmware version?
- jhibbardNov 19, 2023Aspirant
- schumakuNov 29, 2023Guru - Experienced User
In general, even if Netgear does allow us using Beta test hardware later on, and allows us to install the latest public released firmware. Please be reminded that you have signed an NDA, please keep all feedback, project, and product information completely confidential.
