jellebos's avatar
jellebos
Initiate
Sep 15, 2016
wc7500 5ghz only 36 channel in use
Hello,
My name is Jelle and i'm working in education in the Netherlands.
I have a question about the controller wc7500
I have 15 dual-band wifi accesspoints.
All the AP on 2.4ghz are spread automaticly over all available bands. On the 5ghz band all the AP are locked in on the channel 36. What is the reason? The controller is set-up to choose automaticly the best channel
Thank you!
Jelle
  • Hello jellebos,
    Welcome to the community!
    I suggest looking at the Channel allocation Configuration > Wireless > Basic > Channel Allocation and see if the channels are enabled:
    I'd like to know what firmware version is loaded on the controller and if it has been working fine before.
    Thanks,
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello jellebos,
    Thanks,
  • JohnRo's avatar
    JohnRo
    Hi jellebos,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    Thanks,
  • Thank you,
    I load New firmware and Make the changes in the example above. problem solved
    • JohnRo's avatar
      JohnRo
      Hi jellebos,
      That's great! Please feel free to open a new topic if you have more questions. :)
      Thanks,
ProSupport for Business
