texusn's avatar
texusn
WC7520 is bricking WNDAP360 as it updates to its firmware
I am running into an issue migrating WNDAP360 APs to WC7520 Wireless LAN Controller.  So far it has bricked 2 of the 3 APs as it updated their firmware.     The WC7520 is running firmware 2.5.0.4...
  • LaxmankumarG's avatar
    LaxmankumarG
    Jul 16, 2018
    Hi,
    Thanks for your quick and detailed response. We could see two problems from the details you have provide.
    1. VLAN Configuration.
        - Management VLAN and Untagged VLAN should be same, in your case Management VLAN is 4 but untagged VLAN is 1. Please make sure that both of these params are equal and untaggedVLAN is checked.
    2. Configuring the Controller IP properly in AP IP Settings.
        - In AP   Configuration->System-> page, you will see the field Controller IP, please put the controller IP 192.168.4.21
    As you don't have the access to AP now, you can follow the procedure below to bring up the network from the scratch.
    Controller recovery steps.
    1. Hard reset the Controller by pressing Reset button more than 10 seconds
    2. After the hard reset, Controller will get assigned to default IP 192.168.0.250
    3. Login to Controller using default ip i.e 192.168.0.250 (by configuring laptop with static ip 192.168.0.xx)
    username "admin" and password is "password"
    1. Now configure the controller ip address as
                                                 Static IP :           192.168.4.21
                                                 Subnet mask      255.255.255.0
         Default Gateway 192.168.4.1 (or According to your network)
          Primary DNS Server -According to your network
                                                  Management VLAN 4
                                                  Untagged VLAN   4(It should be Checked)
     5. Apply the changes--> Controller will save the changes made
    Note: At this point in time you will not be able to access the controller UI because the controller and laptop are in two different subnets. Please make sure the laptops IP is changed to something like this 192.168.4.xx (where xx is the unique number). for example the laptop IP you can configure as 192.168.4.20
    AP recovery Steps
    1. Hard reset the AP by pressing Reset button more than 10 seconds
    2. After the hard reset, AP will get assigned to default IP 192.168.0.100
    3. Login to AP using default ip i.e 192.168.0.100 (by configuring laptop with static ip 192.168.0.xx)
        4.Go AP Configuration-> System -> IP/VLAN tab configure the following:
                              Ip Address    : 192.168.4.32
                              Subnet mask: 255.255.255.0
                              Default Gateway: 192.168.4.1 (or According to your network)
              Under VLAN settings please configure the following:
                              Management VLAN :  4
                            Untagged VLAN       :  4 (It should be checked)
              Under the Configuration->System->Controller Settings page configure the following:
                             Controller IP
                              192.168.4.21
    1. Apply the changes
ProSupport for Business
