danpool
Jul 21, 2016Aspirant
What Wireless Controller is compatible with WG102 Access Points?
Hi there, Is it possible to set up managed wireless with the WG102 Access Points? I.e. So we can we connect a controller that will intelligently pass over the connection to other points, depeding...
- Jul 21, 2016
Hi danpool,
I regret to inform you that there is no wireless controller that supports the WG102 access point.
If you need to use a wireless controller within your existing network, I suggest that you will need to replace the WG102 access points with the NETGEAR access points that is supported by either of the following wireless controllers: WC9500 and WC7600. Click on the links below to know more.
WC9500 ProSAFE® High Capacity Wireless Controller
WC7600 ProSAFE® Premium Wireless Controller
DaneA
NETGEAR Community Team
