Sannlo
Nov 13, 2023Aspirant
Wireless Access Point comparison between the WAX Range (WAX218, WAX220, WAX610, WAX620 & WAX630)
Greeting Netgear Community, I would like to seek your advice and knowledge regarding setting up my home WIFI connection. I am based in Melbourne and recently moved into a two-story house. ...
schumaku
Nov 13, 2023Guru - Experienced User
The point is that WPA2-PSK is very simple, using simple locally generated crypto keys, allowing seamless roaming with just the same SSID and the same WPA2-PSK set.
For WPA3-SAE, you need some infrastructure support to exchange the crypto keys to allow seamless roaming. In the case if the WAX6xx this is a feature the Insight cloud does facilitate.
If you don't care about reliable security, continue to deploy WPA2-PSK. If you expect almost seamless roaming with multiple APs operating WPA3-SAE, there is no way around Netgear Insight.
- SannloNov 15, 2023Aspirant
Thank you for your reply, I've purchased two of WAX625 AP.
Do you have any advise/ guides (locations) that can assist me with setting up these AP.
Regards San
