Adejong
Oct 05, 2015Aspirant
WMS5316 impossible to ad WNDAP350
hello i having the following issue on my WMS5316 : when i try to add a new WNDAP350 i have the following message : Only 16 Access Points allowed in Managed List I only have 10 AP's liste...
- Oct 07, 2015
Hi Adejong,
You'll probably have to do it after operation hours, the AP's will reboot once they are updated.
If you need more assistance, will be happy to help.
Thanks,
Adejong
Oct 07, 2015Aspirant
Hello
I already tried to update firmware of WNDAP350 but the updated one where no longer detected by WMS5316 !
As i have 11 WNDAP350 this means a long service interuption time ...
Also i have found out that in firmware version 3.0.4 for wndap350, there is a bug fix for my issue see:
http://kb.netgear.com/app/answers/detail/a_id/29894
Fixed false notifications of Max clients exceeded even when it was not.
Is there a way to update firmware without loosing service ? since i'm in a production environment.
Kind regards
JohnRo
Oct 07, 2015NETGEAR Employee Retired
Hi Adejong,
Thanks,
