zappullae
Dec 20, 2016Aspirant
WNDAP660 Internet Access Keeps Loosing Access
My WAP keeps loosing access to the internet and it does it quite often; 6 times an hour, all my wireless devices loose Interment access. They all have WIFI connectivity to the WAP and maintain their local IP but can't download even a simple page like google.com. All devices hard wired to the same firewall/switch do NOT have a problem connecting to the net. I have to turn off and on the device's wireless connection to regain access but that only works for a few minutes.
To get longer lasting connectivity I have to power cycle the WNDAAP660. After a power cycle it will run for potentially a couple days before acting up. I've noticed other users have the same problem.
I have the latest firmware 3.5.20. So at this point its worthless piece of garbage that I have to pay for support for. Does anyone have any ideas before I chuck it in the garbage and never buy another netgear product again?
Dear All
We have made potential fix for this kind of issue. Could you please reach us https://www.netgear.com/support/contact.aspx to get the patch image?
Thanks
Raghu
- JohnRoNETGEAR Employee Retired
Hello zappullae,
Welcome to the community!
Sorry to hear about the issue you are having with the AP. I looked up the case and it was indicated that if the issue comes back after the factory reset and firmware update the device will be replaced. I have talked to support and asked them for someone to contact you and process your RMA. The product that you have has a Complimentary NBD (Next-Business-Day) replacement, so you there should be no charge.
I hope this helps you out.
Thanks,
- zappullaeAspirant
Thank you I will contact them. I'm trying one thing right now. I set the 5G chanell to auto. It was at at chanell 11. I will let u know in a few days.
Hi zappullae,
That was one of the suggested steps on your previous contact with support. We'll wait for your feedback.
Thanks,
- zappullaeAspirant
