bhinkston
Apr 07, 2022Tutor
Insight Cloud not showing correct topology...
So, I started with an internal network of all Netgear products with a Linksys Wifi Router. When using the Insight Cloud Portal, the Topology was perfect. I swapped out my Linksys Wifi Router for...
michaelkenward
Apr 08, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
I will move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
