cifellic's avatar
cifellic
Insight Cloud Portal - I am unable to disable SSID
.  The portal shows the SSID as disabled,  yet my devices see and can connect to the SSID.  The portal also shows the devices on that SSID that I have disabled.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    cifellic,
    Was this working before?
    What device is being managed by NETGEAR Insight wherein you wanted the SSID to be disabled?
    DaneA
    NETGEAR Community Team
    • cifellic's avatar
      cifellic
      Yes it was working before,  I have 3 wac 510 units.  It was working before the last firmware/insight update.
      • DaneA's avatar
        DaneA
        cifellic,
        Since the SSID shows disabled on the Insight portal, kindly try to enable it then disable it.  Then, observe if the same problem will occur.
        DaneA
ProSupport for Business
