DDignam's avatar
DDignam
Can the router backup be restored to a replacement system
I just purchaed an Orbi Pro Router with 2 Satellites. Unfortunately I'm in the UK and it came with power adapters with continental plugs. I've used adapters to get things up and running. A replacement system is on the way and I'm wondering if I can simply restore the backup to the replacement system ?
Dan
  • DDignam,
    Welcome to the community! :)
    You can restore the backup configuration to the replacement Orbi Pro WiFi System that you will receive.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    DDignam,
    DaneA
    • DDignam's avatar
      DDignam
      Sorry for the delay in responding, took a while to get replacement units with UK plugs, and then had to wait for a good time to take the internet away ...
      Anyway, worked like a charm, thx !
ProSupport for Business
