Andrew1918
Jun 04, 2022Aspirant
devices not connecting to satellite( SXR80)
Hi every
I have placed the router on the first floor at front house,satellite downstair at the back ,which is 20 meters apart,
The satellite is running ethernet backhaul .
Most devices not connecting to satellite,the printer place next to the router,but it connected to the satellite,
How to I setup the 2.4g and 5g wifi performance?
Regards
- JohnD333ApprenticeLots of setup issues for lots of people.
Big deal is when you setup, or update firmware, the main router ALWAYS starts first and is up and running about a minute before any sats. So everything connects to main router regardless of how poor the signal this is. If a device is a phone that moves around, it will seal out a better signal as it moves, but for iot and other fixed location devices and pc’s, all you can do is restart those devices or toggle their Wi-Fi’s off then on a few seconds later EVERY time you update firmware.
Also after being told by tech support to buy a second day to improve performance, another tech confirmed that 20 meters is about ok for direct router link, even if a sat splits the distance and is a lot closer.
A nice system, but not as nice as the hype. - plemansGuru - Experienced User
how far apart are they? (router/satellite)
What materials is your home made from on the interior walls?
What do you have your broadcast strength setup?
- Andrew1918Aspirant
Its the device themselves that decide whether to connect to router or satellite. Its not actually the router/satellite that decide it. Some devices tend to be "stickier" than others. You can try turning down the broadcast power if you think devices are picking up a certain device more than others.
