DoctorC's avatar
DoctorC
Does Netgear Orbi have built in modem as we need to connect directly to office internet connection
hello all,
We have a new office opening and an internt conenction provided already. I want to order an Orbi SXK80B4 but need to know if the Orbi primary unit has a built in modem in case the internt provided is raw and without a modem.
can anyone help on this?
thanks
David
  • plemans's avatar
    The SXK80 doesn't. But I wouldn't recommend one with an integrated modem anyway. For more than 1 reason.
    reasons:
    1. If its has an integrated modem, the isp controls the firmware updates. Not a good thing from a business perspective as the ISP rarely updates
    2. If you switch isp's, you have to get a different router if they aren't compatible
    3. If you upgrade services/speeds, the modem might not be rated for it and you'd again have to buy a new router with it
    4. It might not be compatible with your isp. You need to check with your ISP to see what gateway's are compatible.
    • DoctorC's avatar
      DoctorC
      thanks, i didnt expect it would have as normally they dont and the ISP in this case Colt, should provide the modem as part of their NTE and present a RJ45 connection to us the customer.
      I am trying to get Colt to confirm this but its proving painful to get the details from them.
      • plemans's avatar
        I've never even heard of Colt as an ISP so I've got no idea what they use for standard modem/gateways.
ProSupport for Business
