Flash008
Jan 21, 2019Luminary
Don’t buy Orbi Pro…Buy something else. Anything else…
I own Orbi Pro with two Pro Satellites. I also own the Orbi Outdoor RBS5OY.
Here are my problems and reasons to avoid anything produc...
- Jan 22, 2019
Dear customer,
Throughput issues :
Please open a support case for the throughput issue you are facing on 2.2.2.20.
We will try to get back on it asap. you can use support chat window inside Insight app to contact netgear support. We take quality and stability very seriously inside netgear across all our products. We do a full stabilitiy test and full regression test before we release any firmware out to our customers. so there should be something more than just simple regression issue.
General topic brought out in this thread:
2) Orbipro vs Orbi
Orbi pro software has many more features than home Orbi.
here is a quick list ( not in any order and is not complete)
1) Insight support allows manging OrbiPro remotly via insight app as well as full fledged insight webportal. (feature supported is growing every release of insight)
2) 3 SSIDs. 2 Pvt SSID and 1 guest SSID. user can map SSID1 and/or SSID2 to ethernet ports.
3) Guest SSID support basic captive portal, Facebook captive portal that allows retailer to move traffic to their facebook page when giving out free wifi. that feature has multiple options that includes giving guest wifi for people without facebook login also.
4) SRR60 (OrbiPro router) supports SRS60(4 port desktop), SRC60(OrbiPro ceiling/wallmount that works on Poe+) and RBSY50 (Outdoor). (as off Jan 2019)
We are trying to keep a quaterly cadence bringing in maintiance releases that will have bug fixes,
3)Different levels of Pro/SMB products.
We have three levels/familes of wireless products for SMB.
Insight managed WAC5xx (WAC510, WAC505, WAC540.....)
Insight managed OrbiPros (SRR60 + SRS60/SRC60/RSBY50)
Desktop Access points (WAC104, WAC124)
Mainstream enterprise/SMB APs:
- WAC510 (2x2, Long range, wall mount/celing mount) ,
- WAC505 (2x2 omni directional antenna, can be used as desktop, wallmount and ceiling mount)
- WAC540 (Tri-Radio 2x2+2x2+4x4, wall/ceiling mount)
few of support features include WPA-enterprise, fastroaming, VLAN tagging, LAG, LLDP etc. Almost all of useful enterprise features like Instant Wi-Fi (automatically choosing best channels, Tx power for all the AP in a location)
OrbiPro :
4x4 is dedicated for backhaul.
2x2 + 2x2 for serving clients.
This work as router/access points and many of the pro features. but is mainly ment for DIY user who do not want lots of custom configurations and overrides.
WAC124 : is a desktop AP/router that is capable of 4x4 speeds.
4)Software release cadence :
We are trying to keep a quaterly cadence bringing in maintiance releases .
If we see a more important bug and fix, we release the fix asap. so far we have about 7 release for OrbiPro. every release we have added new feature and added
nmhTester
Jan 22, 2019NETGEAR Employee Retired
Dear customer,
Throughput issues :
2) Orbipro vs Orbi
OrbiPro :
- Flash008Jan 22, 2019Luminary
WOW! A response! Something hard to get from Netgear.
Thank You!
- Orbi vs Orbi Pro – Very interesting response to attempt separating Orbi and Orbi Pro as different products. So, by your opinion…If I take a base Honda Accord, add a Bose Premium Radio, 2 additional speakers, additional options for rims and tires and maybe some color paint choices…Does this made the Honda Accord different? Or, is it the same car, same frame, same engine, same 90 percent everything, only with some add-ons that the consumer may or may not care for?
- You speak about bug fixes. OK, How many “quarterly releases” does it take to resolve wired backhaul and many other issues that have been reported repeatedly via this forum and many others. Here is a list…(not in any order and is not complete)…
Wired backhaul still not working properly. Still using STP, not RSTP. The Orbi Mobile app cannot connect to Orbi via any AP node being used that is connected via wired backhaul. Of course, many wired backhaul users will be connected via a managed switch. Netgear seems to be very anti-managed switches (though you do sell them). What business on Earth is not going to have at least one managed switch. Many users reporting slowness of using ethernet when wired devices are connected to Orbi. And I believe it is NETGEAR who is still instructing users to “disable Daisy Chain” because your developers may have broken that feature and it works backwards. Still not fixed yet.
Orbi Satellites being forced to the main Orbi router, despite a satellite being closer and with a much better signal. I, and many other, witness a freshly booted, and firmware laoded, Orbi show Satellites connecting to closer/better satellites to create a true MESH. But within minutes all satellites will be FORCED to the main router…causing slower speeds (throughput). This has been reported for months, maybe even a year….Not fixed yet.
You can only user the WAN port with the main router. Otherwise you get the purple light and internet will be reported as DOWN. Reported for MONTHS. Not fixed yet.
Ability to have separate BSSIDs for 2G and 5G….I had a Playstation 4 Pro (802.11AC device) within 6 feet of the main Orbi Pro Router. Fresh firmware and factory reset. No excuses Netgear can provide. I did a status check of the PS4…Its connected via 2G…Not 5G…I tried to play some games…COD BOPs4….Disconnected from server. Can’t connect to server In the middle of a game and something I have never seen...An icon showing the game disconnected from the physical network. LOL, never seen that icon in my life. I moved the PS4 back to my Cisco switch….works beautifully, played for hours without a problem. Sony’s fault, right??? Though I was hoping I could remove another Cat7 cable from my life. Guess not….Thanks $2000 Orbi Pro….Still not fixed yet….
VLAN Support for BSSIDs for Router and AP mode…..Still not delivered yet. Does it occur to Netgear that MAYBE a BUSINESS CUSTOMER wants to use their REAL Firewall Layer-7 UTM/Router. Maybe they have multiple subnets and want logical separation??? Maybe a BUSINESS customer understands that WIFI devices really should be on their own network due to several known methods of hacking, phishing, malware, spyware, etc, etc….Does not Netgear know with all of their BUSINESS experience that no true network engineer is going to allow WIRELESS to live on the same network space as wired devices and servers????? Are you TRYING to compromise your customers security?
Better QoS support…NOPE…Not yet….But as your forum says for all things…
.”We are reviewing this request and will have a plan for implementation in an upcoming firmware release.” – Yeah….SURE YOU WILL…in the year 2020…LOL! Maybe…
I have one satellite connected via wired backhaul….After a full factory reset, reboots, and now needing to re-configure EVERYTHING as I rolled back to your previous regression tested firmware (LOL). I changed my 2G channel to 11 last night. To avoid problems with Zigbee devices on a lower band. Of course all units had to reboot/reset for the change. Which means every 5G WIFI client gets disconnected (for a 2G channel change). After reboots, syncs, and several attempts to change that channel. The wired backhaul satellite will not take the new channel. Let me guess…..CALL SUPPORT????
This is just a short lists of Orbi and Orbi Pro problems. I can continue, but time is limited.
All of these problems and feature requests have been reported to Netgear for MONTHS. Some over a year…..So, how many firmware releases, and MONTHS, do you need to fix these problems?
Clearly Netgear has had TIME to develop, create, prototype and field test and QA newer products. As you share with us….
GET THAT NEW MONEY NETGEAR!!!! That is clearly all that matters to you....
Tell me Netgear Employee. What’s your support plan for these other products? Hopefully its better than Netgear’s Orbi and Orbi Pro.
“so far we have about 7 release for OrbiPro. every release we have added new feature and added”…(Next time have someone else write the response. Grammar corrections needed…)
Forgive my ignorance. Ummm…7 releases. Why is Orbi Outdoor still 3 releases behind Orbi Pro? How do new features you claim carry forward on a “business” or consumer network when one of the devices DOES NOT support that feature because it’s using older code?
You claim…
”We do a full stabilitiy test and full regression test before we release any firmware out to our customers. so there should be something more than just simple regression issue.”
Please understand that I am a 20 years I.T. Pro. I spend countless days, weeks, months looking at scripts and APIs, etc. Every time a software vendor releases a new version of their product. The first question is ALWAYS….”Will it support my existing work/configuration?”
We answer yes or no, based on the software OEMs ability to properly perform regression testing to insure all prior SDK commands continue to work.
Can you imagine the customer response if I replied.
“No, kinda, maybe…you may need to WIPE YOUR ENTIRE CONFIG, RESET TO FACTORY because some older “NON-WORKING” commands could be left lingering within and cause problems.” Basically…NO! We don’t do quality regression testing.
Doesn’t regression testing mean, “we ran extensive tests to insure old commands and scripts and configurations work with the new code”. I am sure that is what it means….So, why would a full reload be required nearly every time Netgear releases new firmware? If Cisco, HPE, Arista, Juniper, Riverbed, Ubiquitior other premium network OEMs did this….They would get their product REMOVED….
But this is Netgear’s answer to most problems. FACTORY RESET, RELOAD FIRMWARE and re-do everything. Oh, and don’t forget to DISABLE EVERY FEATURE ON YOUR ORBI PRODUCT per Netgear if experiencing problems… There is no business on PLANET EARTH that would accept that answer.
And now you are introducing “CEILING MOUNTED ORBI”….WOW!!! YAY!. Now your customers can put their life at risk and climb ladders every time Netgear releases new firmware that doesn’t work or breaks your Orbi for the 10thtime, and Netgear’s response will be….”Climb on ladder, with pointed object required to press and hold the reset button, then wait for light to turn WHITE and then press Sync button”. And you want the customer to do this every quarterly release with your “regression tested code that provides bug fixes for heavily reported issues over the past YEAR!!!!” Only to discover many of the problems still exist…?
Good luck with that…
Thank you again for your response and solutions you provided to our many Orbi problems. I don’t see any solutions. But maybe your response is hiding it. I will go back a read it again.
- schumakuJan 27, 2019Guru - Experienced User
Not sure where you have seen a confirmation that Orbi Pro will ever get proper VLAN support. There was a discussion with the Netgear Business Unit General Manager johngm a while back concluding there will be just a better seggregation between the three SSID networks.
In a way I would like htis discussion moved to the Connect with the SMB GM so John does get the right attention on what is (not) going on with the Orbi Pro.
Both Insight and Orbi Pro was initially released in 2017, with about one month difference.
Some more things are concerning me beyond of the ongoing Orbi and Orbi Pro problems
- How comes a what supposed to be simple to deploy network infrastructure needs manual user configuration for wired vs wireles backbone?
- Why aren't the (fast, expensive, energy intensive) 80211ac 1733 Mbit/s 5 GHz radios made available to the user access if not serving the network backbone?
- How did it came that Netgear released an Insight router (BR500) which is obviously based on the very similar [limited] archotecture like Orbi Pro router, namely no workable multi-VLAN on tagged connections?
- Flash008Jan 27, 2019LuminaryPer your question of my comment...”VLAN Support for BSSIDs for Router and AP mode”.
My comment comes from Netgear’s response to my question MONTHS AGO. When the “vlan supported firmware” was released. I use Orbi via AP Mode and asked Netgear on this forum when vlan support would be enabled using AP Mode. The reply from Netgear was “in a future release”.
Case-and-point...STILL NOT DELIVERED!!!
