DimitriVisser's avatar
Jun 07, 2026
[HELP] SXS50 satellite not pairing as mesh unit after factory reset – tried everything
Hi everyone,
I'm hoping someone can help me out. I have an Orbi Pro WiFi 6 AX5400 kit (SXR50 router + SXS50 satellite) and after a factory reset of the satellite, it refuses to reconnect as a mesh unit. It only connects as a wired client when plugged in via ethernet.
My setup:
  • Router: SXR50, firmware 4.3.2.200, IP 192.168.1.233
  • Satellite: SXS50, MAC 34:98:b5:a7:b0:61
Background: The router and satellite were purchased as a kit and worked correctly together for a long time. After performing a factory reset on the satellite, the mesh pairing was lost and I haven't been able to restore it.
What I've tried:
  • Factory reset of the satellite (multiple times)
  • Sync button method on both router and satellite
  • Connected satellite via ethernet cable for an extended period to allow firmware sync
  • Updated router firmware to 4.3.2.200
  • Tried adding satellite via the + wizard on orbilogin.com
  • Tried adding satellite via the Orbi Pro app
What happens:
  • With ethernet cable connected: satellite shows a blue light and appears in the network topology as a regular client (Type: Client, interface LAN2) — not as a satellite
  • Without ethernet cable: satellite shows a magenta light and cannot establish a wireless mesh connection
  • The Satellites page in both the web interface and the app consistently shows "No Satellite available"
My question: Is there any way to re-pair the SXS50 as a mesh satellite to the SXR50 after a factory reset? It seems like the mesh configuration is lost and the normal pairing methods aren't working.
Any help would be greatly appreciated!
  • FURRYe38's avatar
    Looks like you updated the SXR FW first when you should have updated the SXS FW first, then SXR lastly.
    Try downgrading the SXR back to prior working version, then see if SXS will connect then, if so, update it first, the the SXR lastly.
    • DimitriVisser's avatar
      DimitriVisser
      I understand that downgrading the firmware is prohibited due to security so no option. I tried to connect them via utp but also not working.
       I’m calling it a day. Tomorrow a new networking day. Thx for the suggestion.
      • FURRYe38's avatar
        Where does it say that's prohibited?
        You can downgrade to prior working FW, long enough to get the SXS reconnected, then update the SXS, then upgrade the SXR.
ProSupport for Business
