BE2181
Mar 19, 2022Tutor
Home Setup
Using the above devices, I have set up my home system. The router and satellites are hardwired; however, the satellites do not appear as such on either the Insight app nor the webpage. On the Insight app both display a mesh-link status: Disconnected. On the webpage, the both display in the wireless, not wired, section of attached devices. The wifi signal is strongest at the router and dissipates as you move further away in the home. The signal does not get stronger near the satellites as one would expect.
Can anyone help point me in the right direction?
