bernardh
Jun 01, 2020Aspirant
Log Location SRR60 Orbi Pro
My network sponanteously rebooted. (It was not caused by a firmware update as it had been updated previously.) I can find the log after the reboot in orbilogin>advanced>administration>logs, but I...
- Jun 05, 2020
Orbi Pro doesn't store system logs in flash because of limited storage. Since 2.4 release, the device supports Syslog. You can enable the feature and build a syslog server to retrive devices logs.
Bruce
BruceGuo
Jun 05, 2020NETGEAR Expert
Bruce
bernardh
Jun 09, 2020Aspirant
BruceGuo wrote:Orbi Pro doesn't store system logs in flash because of limited storage. Since 2.4 release, the device supports Syslog. You can enable the feature and build a syslog server to retrive devices logs.
Bruce
Thanks Bruce
I'll set this up so that I can look at future reboots if necessary.
