JAMBE
Jun 27, 2025Aspirant
Orbi Pro - SRR60, SRC60, RBS50Y problem
Hello, I have a wifi system in our store with a SRR60 Router, two SRC60 indoor satellites and one RBS50Y outdoor satellite. I am having problems with our ESP32 (arduino) devices that they kee...
Jun 27, 2025Guru - Experienced User
What is the size of buliding? Sq Ft?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between SRR 📡 and SRS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Does this happen if you turn OFF all SRS?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Does this happen if you factory reset the SRS and SRR and setup from scratch?
Try following this with the SRR to factory reset the system and setup from scratch with a wired PC and web browser:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
