JAMBE
Jun 27, 2025Aspirant
Orbi Pro - SRR60, SRC60, RBS50Y problem
Hello, I have a wifi system in our store with a SRR60 Router, two SRC60 indoor satellites and one RBS50Y outdoor satellite. I am having problems with our ESP32 (arduino) devices that they kee...
Jun 27, 2025Guru - Experienced User
What is the size of buliding? Sq Ft?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between SRR 📡 and SRS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Does this happen if you turn OFF all SRS?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Does this happen if you factory reset the SRS and SRR and setup from scratch?
Try following this with the SRR to factory reset the system and setup from scratch with a wired PC and web browser:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
JAMBE
Hello, thank you for your answer,
Firmware for all devices is the latest for the moment : Outdoor one : V2.7.2.102 / indoor and router : V2.7.3.100
Our modem is from BASE (part of Telenet in Belgium) , CH7465LG-BA , but that wont be part of the problem since its all internal LAN, so the system even works without a modem connected, no internet needed.
Its a big building (4 floors), but tried closer and furder away, no change, typicaly there is one AP per floor + the outdoor one , tried putting the ESP32's in the same room, no change.
It "think" I have tried it without any satellite plugged in, but not 100% sure, I will try this later when I can disconnect everything to rule that one out (incase its maybey the backbone wifi interfering, might be good point)
channels tried on auto, tried setting the usual best channels 1,6 and 11 , no change, the ESP32's only have 2.4Ghz , but tried combined 2.4Ghz/5.0Ghz network and seperated , no change.
I factory resetted everything last week (and changed from router mode to AP mode during setup) no change, I always configure via a PC and webbrowser, I dont use apps for stuff like this :)
I will try without satellites and let you know,
Hans
